2014 - 2018 Corvette: Service Bulletin: #PIP5248D: Stalling Shudder And/or Hard shifting Into 1st Gear Or Reverse Vibration On launch
#PIP5248D: Stalling Shudder And/or Hard shifting Into 1st Gear Or Reverse Vibration On launch (With Excessive Crankshaft End Play) - (Aug 10, 2017)
Subject Stalling Shudder And/or Hard shifting Into 1st Gear Or Reverse Vibration On launch (With Excessive Crankshaft End Play)
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2015 - 2018
All
All
6.2L LT4
All
Cadillac
Escalade
2015-2018
All
All
6.2L L86
All
Chevrolet
Camaro
2016-2018
All
All
6.2L LT1 LT4
All
Chevrolet
All
All
6.2L LT1 LT4
All
Chevrolet
Silverado
2014-2018
All
All
4.3L 5.3L 6.2L LV3 L83 L86
All
Chevrolet
Suburban
2015-2018
All
All
5.3L L83
All
Chevrolet
Tahoe
2015-2018
All
All
5.3L L83
All
GMC
Sierra
2014-2018
All
All
All
GMC
Yukon Module
2015-2018
All
All
5.3L 6.2L L83 L86
All
Supersession Statement
This PI was superseded to update Models. Please discard PIP5248C.
Condition/Concern
Corvette Only
Customers may have a Corvette that exhibits one of the following conditions:
  1. Stalling, Shudder and/or Hard shifting into 1st gear or Reverse for manual transmission or Stalling after a driveline replacement.
  2. Auto transmission it could be a vibration on takeoff or clunk noise.
Truck, SUV, Camaro, CTS –V
Clunk when shifting into reverse or drive (automatic)
The crankshaft and or Thrust Bearing needs to be replaced, please use following information before considering a crankshaft replacement.
Recommendation/Instructions
This concern could be caused by excessive crankshaft end play.
Check to determine if the crank shaft end play is within specification 0.0015–0.0086 in (0.040–0.220 mm). See eSI.
If end play is found to be out of specification, remove engine and inspect for possible Crankshaft thrust bearing and/or crankshaft for wear.
Note: If bearings and crankshaft look like components in attached picture, damage has not occurred.
Inspect thrust bearing for wear on one side and crankshaft on that “mating” surface.
If wear is evident (3 vertical channels worn off) replace connecting rod bearings, main bearings, thrust bearing and crankshaft.
Corvette Only
For this repair the oil tank with lines and oil cooler are both required to be replaced if equipped.
Note: Be sure to follow all SI documents for DSA replacement
For all other Crankshaft concerns
  • As always, Please be sure to complete the SI diagnostics and the Cost Comparison Worksheet for Assembly Repair vs Replacement to determine if the engine requires a repair or replacement
  • Be sure to Follow the latest version of 09-06-04-026G to verify the ECM calibration is not an Aftermarket cal.
Note: It is required on dry sump engines, the oil tank and lines should be replaced when replacing and/or repairing the engine.
Note: Also if equipped, the oil cooler is also required to be replaced.
If the customer prefers to KEEP the original numbers matching engine please call TAC for repair direction
Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
4066750
Crankshaft Replacement
Use Published Labor Operation Time
