2014 - 2019 Corvette: Service Manual: Roof Lift Off Replacement and Headliner Replacement
Estimated Reading Time: < 1 MinuteAttached below is a document from the 2019 Corvette Service Manual with instructions on replacing the removable roof panel as well as the headliner trim panel for the solid roof panel. This should apply to all C7 Corvettes starting with the 2014 model.
