2014 Corvette: Techlink Article: Winter Tires
Estimated Reading Time: 1 Minutes Source: GM TechLink
Date: September 5, 2013
The 2014 Corvette Stingray is equipped with Michelin® Pilot Super Sport® ZP run-flat summer-only tires. (Fig. 9) The Michelin Pilot Super Sport ZP tires are unique and aggressively tuned to provide outstanding handling, grip and road-holding capability in dry conditions.
Fig 9
If frequent driving on ice or snow covered roads is expected, customers may want to consider installing winter tires.
With winter tires, there may be decreased dry road traction, increased road noise, and shorter tread life. After changing to winter tires, drivers should be alert for changes in vehicle handling and braking.
Due to the limited production of the Corvette Stingray, the only winter tire currently available is the Michelin Pilot Alpin PA4. Other tires may become available at a later date.
- Thanks to Art Spong
