2015 - 2016 Corvette Z06: Service Bulletin: 100 Octane Fuel Calibration
Chevrolet Performance – 100 Octane Fuel Calibration - Z06 MY15-16
Updated Date:Dec 21, 2016 10:50 ET
  Chevrolet, Buick, GMC, and Cadillac Dealers
  Chevrolet Performance announces the launch of "100 Octane Fuel Calibration" for a 2015 or 2016 Z06 Corvette to the Chevrolet Performance Parts Program.
  Important Information:
  The 100 octane calibration is optimized for track use with 100 octane fuel. The calibration changes to improve performance with higher octane fuel have not affected emissions, and  this calibration is 50‐State emissions legal with CARB Executive Order D‐126‐41. If used on the street with lower octane fuel, 93 octane rating or less, drivability issues may be experienced. In particular it is possible that detonation or spark knock may occur in hot  climates or hot running conditions with fuel that has a lower octane rating than 100. Spark knock results in the ECM retarding spark timing which will/may result in reduced engine performance. We recommend using 100 octane fuel with this calibration to maintain peak  engine performance.
  Note to Dealers: To reprogram the "100 Octane Fuel Calibration" please call Techline Customer Support Center ﴾TCSC﴿ at 1‐800‐828‐6860 for programming requirements and instructions. Please be ready to provide the VIN prior to calling. TCSC will bill the Dealership directly for the calibration.
  Warranty Information: Re‐flashing the vehicle with this calibration maintains the vehicle’s warranty.
  Calibration Flash:
  MY2015/2016 Z06 PERFORMANCE UPGRADE
  Part Number: 12677967
  MAP $332.50
  IMPORTANT: FOR USA SALES ONLY
Attached document is below:
