2015 - 2019 Corvette: Service Bulletin: #16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle
#16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle - (Apr 6, 2017)
Subject Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS
2016
2017
Automatic 8L45, 8L90 (M5T, M5N, M5U, M5X)
CTS Models
CT6
Escalade Models
2015
Chevrolet
Camaro
2016
2017
2019
Silverado
GMC
Sierra
2015
2017
Automatic 8L90 (M5U, M5X)
Yukon
Involved Region or Country
North America and N.A. Export Regions
Condition
Some customers may comment that the transmission exhibits a harsh 1-2 shift on the first shift of the day, typically under light throttle.
Cause
This condition is due to the initial clutch fill time of the 2-3-4-6-8 (C4) clutch.
Information
Some customers may experience a flare condition on the first 1-2 shift of the day or after the vehicle has been parked for several hours. The condition may have developed after the replacement of a complete transmission assembly or the replacement of the stator support to correct a delayed engagement condition. This is most likely to occur under light throttle conditions. Subsequent 1-2 shifts have acceptable shift feel. Replacing transmission components will not correct the condition.
Correction
Important: Replacing transmission components or complete assemblies will not improve the condition.
The first 1-2 shift of the day may be harsh. The customers’ vehicle should be compared to a like vehicle under the same driving conditions. Do Not replace any parts for this condition.
Note: This condition will not impact the designed performance or reliability of the vehicle.
Version
3
Modified
Nov. 18, 2016 - Revised the Cause section.
April 6, 2017 - Added models and Revised the Condition, Cause and Correction sections.
