2016 - 2017 Corvette: Service Bulletin: #PIP5330B: Coolant Loss And/Or Coolant Odor
Estimated Reading Time: 1 Minutes#PIP5330B: Coolant Loss And/Or Coolant Odor - (Jun 15, 2017)
Subject: | Coolant Loss And/Or Coolant Odor |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS-V |
2016-2017 |
All |
All |
6.2L LT4 |
All |
Cadillac |
Escalade |
2015-2017 |
All |
All |
6.2L L86 |
All |
Chevrolet |
Camaro |
2016-20117 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Corvette |
2016-2017 |
All |
All |
6.2L LT1 LT4 |
All |
Chevrolet |
Silverado |
2014-2017 |
All |
All |
4.3L 5.3L 6.2L LV3 L83 L86 |
All |
Chevrolet |
Suburban |
2015-2017 |
All |
All |
5.3L L83 |
All |
Chevrolet |
Tahoe |
2015-2017 |
All |
All |
5.3L L83 |
All |
GMC |
Sierra |
2014-2017 |
All |
All |
All |
GMC |
Yukon |
2014-2017 |
All |
All |
5.3L 6.2L L83 L86 |
All |
Supersession Statement:
This PI was superseded to update Engine RPO and modules. Please discard PIP5330A.
- Condition/Concern
A vehicle may have a concern with coolant loss and/or coolant odor after driving the vehicle.
- Recommendation/Instructions
If the coolant is low pressure test the cooling system looking for leaks at the outer head bolts. See below:
If a leak is found the head with the concern will need to be replaced.
- Warranty Information
For vehicles repaired under warranty use:
Labor Operation
Description
Labor Time
4061770
Cylinder Head Replacement - Right Side
Use Published Labor Operation Time
4061790
Cylinder Head Replacement - Left Side
