2016 - 2017 Corvette: Service Bulletin: #PIP5447B: P3400 setting with 8 speed only - (Apr 4, 2017)
Estimated Reading Time: 1 Minutes#PIP5447B: P3400 setting with 8 speed only - (Apr 4, 2017)
Subject: | P3400 setting with 8 speed only |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Camaro |
2016 - 2017 |
All |
All |
6.2L LT1 |
8 Speed |
Chevrolet |
Corvette |
2016 - 2017 |
All |
All |
6.2L LT1 |
8 Speed |
Involved Region or Country |
North America |
Additional RPO/s: |
N/A |
Condition |
The vehicles listed in the PI may have a concern of a DTC P3400 setting |
Cause |
Unknown at this time. |
- Correction
Follow SI diagnostics for DTC P3400 to be sure this is not a false concern.
Document the findings and repair as needed per the service procedure.
Try to capture a GDS2 session for review.
If the concern was not duplicated or repaired following SI, call GM Technical Assistance to set up a case and provide results from SI diagnostics.
