2016 - 2018 Corvette: Service Bulletin: #20-NA-207: Information on Malfunction Indicator Lamp (MIL) Illuminated - DTC P0333 Set - (Oct 6, 2020)
Subject Information on Malfunction Indicator Lamp (MIL) Illuminated - DTC P0333 Set
This bulletin replaces PIP5576. Please discard PIP5576.
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2016
2018
All
All
6.2L (LT4)
All
Escalade
2015
2018
All
All
6.2L (L86)
All
Chevrolet
Camaro
2016
2018
All
All
6.2L (LT1, LT4)
All
2018
All
All
6.2L (LT1, LT4, LT5)
All
Silverado
2014
2018
All
All
4.3L, 5.3L, 6.2L (L83, L8B, L86, LV1, LV3)
All
Suburban
2015
2019
All
All
5.3L (L83)
All
Tahoe
2015
2019
All
All
5.3L (L83)
All
GMC
Sierra
2014
2018
All
All
4.3L, 5.3L, 6.2L (L83, L86, LV1, LV3)
All
Yukon Models
2015
2018
All
All
5.3L, 6.2L (L83, L86)
All
Involved Region or Country
North America, Europe, Russia, Middle East, Israel, Chile, Colombia, Ecuador, Venezuela, Japan, GM Korea Company, China, Taiwan, Thailand, Singapore, Philippines, Other Africa
Condition
Some customers may comment that the MIL is illuminated when shifting the transmission from Park.
Some technicians may find DTC P0333 (Knock Sensor Circuit High Voltage Bank 2) set in the Engine Control Module (ECM).
Cause
DTC P0333 can set due to voltage from the transmission park/neutral signal 1 circuit bleeding into the knock sensor system circuits.
Correction
To correct this condition, follow service information for diagnostic code P0333. If service information does not isolate the concern, then inspect the K20 ECM X2 electrical connector for debris, connector and/or terminal concerns. 
Version
1
Modified
Released October 06, 2020
