2016 - 2019 Corvette: Service Bulletin: #20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set
#20-NA-200: Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set - (Sep 25, 2020)
Subject:  Diagnostic Tip for Malfunction Indicator Lamp (MIL) Illuminated - DTC P0172 and/or P0175 Set
This bulletin replaces PIP5590A. Please discard all copies of PIP5590.
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2016
2019
All
All
6.2L (LT4)
All
Escalade
2015
2019
All
All
6.2L (L86)
All
Chevrolet
Camaro
2016
2019
All
All
6.2L (LT1, LT4)
All
2019
All
All
6.2L (LT1, LT4, LT5)
All
Silverado
2014
2018
All
All
4.3L, 5.3L, 6.2L (L83, L8B, L86, LV1, LV3)
All
Silverado LD
2019
2019
Suburban
2015
2019
All
All
5.3L (L83)
All
Tahoe
2015
2019
All
All
5.3L (L83)
All
GMC
Sierra 1500
2014
2018
All
All
4.3L, 5.3L, 6.2L (L83, L86, L8B, LV1, LV3)
All
Sierra Limited
2019
2019
Yukon Models
2015
2019
All
All
5.3L, 6.2L (L83, L86)
All
Involved Region or Country
North America, Uzbekistan, Russia, Middle East, Israel, Palestine, Colombia, Ecuador, Paraguay, Japan, Singapore, Philippines, Other Africa
Condition
Some customers may comment that the MIL is illuminated.
Some technicians may find one or more of the following DTCs set in the Engine Control Module (ECM).
  • - P0172: Fuel Trim System Rich Bank 1
  • - P0175: Fuel Trim System Rich Bank 2
Cause
This condition may be caused by a possible high pressure fuel pump.
Correction
If SI does not isolate the cause of the rich condition, the following information may be helpful:
  1. 1. Disconnect the dirty air side of the PCV system.
  2. 2. Plug the vacuum supply.
  3. 3. Start the engine and monitor the fuel trims in closed loop.
    • - If the fuel trims return to normal, this is a good indicator that the high pressure fuel pump is leaking.
With this concern, we do not see a lot of fuel in the crankcase, so changing the oil may not isolate the concern.
When the high pressure fuel pump leaks, the PCV will pull the fuel mist straight into the intake, causing the concern.
Version
1
Modified
Released September 25, 2020
