2016 Corvette: Service Bulletin: #16-NA-219: GPS Inoperative, Red Line Across GPS Indicator, or the Location is Stuck in Warren Michigan
#16-NA-219: GPS Inoperative, Red Line Across GPS Indicator, or the Location is Stuck in Warren Michigan - (Jun 30, 2016)
Subject GPS Inoperative, Red Line Across GPS Indicator or the Location is Stuck in Warren Michigan
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Buick
Regal
LaCrosse
2016
2016
All
All
Cadillac
ATS
CT6
CTS
ELR
Escalade Models
XTS
2016
2016
All
All
Cadillac
XT5
2017
2017
All
All
Chevrolet
Camaro
Colorado
Cruze
Malibu
Silverado
Suburban
Tahoe
Volt
2016
2016
All
All
Chevrolet
Volt
2017
2017
All
All
GMC
Sierra
Yukon Models
2016
2016
All
All
Involved Region or Country
North America
Additional Options (RPO)
Equipped with  Navigation Radio RPO IO6
Condition
Some customers may comment the GPS is inoperative, red line across GPS indicator or the location is stuck in Warren Michigan.
Correction
Prior to performing any diagnostics, please check the Onboard Development screen GPS information.
Press the following button combinations to enter Onboard Development Screen:
Buick Models
Power+Home+Menu - release Home first after Development screen is displayed
Cadillac Models
Home+Volume down or Home+Mute
Chevrolet Models
Power+Home+Back or Power+Home+Menu
GMC Models
Power+Home+Menu
Once in Development Screen press NAVI, then Sensors, then GNSS, check Status and GNSS System. If showing Unknown and Invalid - update the HMI with USB and SPS programming. Refer to Human Machine Interface Control Module Programming and Setup in SI.
If showing No Fix and GPS please continue with normal diagnostics referring to SI.
