2017 Corvette: Service Bulletin: #16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated
#16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated - DTC P0747, P0777, P0797, P2715 or P2724 May Be Set Current or History in Transmission Control Module - (Apr 7, 2017)
Subject Harsh Shift, Delayed Shift, Unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated - DTC P0747, P0777, P0797, P2715 or P2724 May Be Set Current or History in Transmission Control Module
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
ATS
2017
2017
SOP
December 6, 2016
Automatic 8L45, 8L90 (M5T, M5N, M5U, M5X)
CTS
CT6
November 17, 2016
Escalade
December 16, 2016
Chevrolet
Camaro
2017
2017
SOP
December 6, 2016
Silverado
December 16, 2016
Suburban
Tahoe
GMC
Sierra
2017
2017
SOP
December 16, 2016
Automatic 8L90 (M5U, M5X)
Yukon
Involved Region or Country
North America and N.A. Export Regions
Condition
Some customers may comment that one or more of the following conditions:
  • Harsh shift
  • Delayed shift
  • Unwanted downshift
  • Transmission stuck in one gear
  • Erratic shifting
  • Hesitation between shifts
  • MIL illuminated
The technician may find one or more of the following DTCs set:
  • P0747
  • P0777
  • P0797
  • P2715
  • P2724
Cause
This condition may be caused by a calibration anomaly in the Transmission Control Module (TCM).
Correction
If you encounter a vehicle with the above concern, reprogram the Transmission Control Module (TCM) with the latest software available on TIS2WEB.
Warranty Information
Labor Operation
Description
Labor Time
2810175
Transmission Control Module Reprogramming with SPS
Use Published Labor Operation Time
Service Procedure
Important: Stable battery voltage is critical during programming. Any fluctuation, spiking, over voltage or loss of voltage will interrupt programming. Install the EL-49642 SPS Programming Support Tool to maintain system voltage. If not available, connect a fully charged 12 V jumper or booster pack disconnected from the AC voltage supply. DO NOT connect a battery charger.
Note: After updating the TCM, complete K71 Transmission Control Module – Setup to run the Service Fast Learn procedure.
Update the TCM to the latest software and calibration available on TIS2WEB. Refer to K71 Transmission Control Module: Programming and Setup in SI.
Version
2
Modified
April 7, 2017 - Updated the Subject and Condition sections.
