2019 - 2021 Corvette: Service Bulletin: #19-NA-218: Ticking Noise from the Engine - (Dec 16, 2020)
Subject Ticking Noise from the Engine
This bulletin replaces PIP5606E. Please discard PIP5606E.
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
CTS-V
2019
2019
6.2L (LT4)
Escalade
2019
2021
5.3L, 6.2L (L83, L86, L87)
Chevrolet
Camaro
2019
2021
6.2L (LT1, LT4)
2019
6.2L (LT1, LT4, LT5)
2020
2021
6.2L (LT2)
Silverado 1500 (New Model 12th Digit VIN = 7) - 4WD
2019
2019
4.3L, 5.3L, 6.2L (LV3, L82, L84, L87)
Silverado 1500 (New Model)
2019
2021
Silverado LD
2019
2019
5.3L, 6.0L, 6.2L (L83, L96, LC8)
Suburban
2019
2021
5.3L, 6.2L (L83, L84, L86, L87)
Tahoe
2019
2021
5.3L, 6.0L, 6.2L (L83, L84, L86, L87, L96)
GMC
Sierra Limited
2019
2019
5.3L, 6.0L (L83, L96, LC8)
Sierra 1500 (New Model)
2019
2021
4.3L, 5.3L, 6.2L (L82, L84, L87, LV3)
Yukon Models
2019
2021
Involved Region or Country
North America, Europe, Russia, Middle East, Iraq, Israel, Palestine, Argentina, Brazil, Chile, Colombia, Ecuador, Paraguay, Peru, Uruguay, Venezuela, Japan, Cadillac Korea (South Korea), GM Korea Company, Thailand
Condition
Some customers may comment that they hear a ticking noise coming from the engine when cold.
  • This ticking noise will mainly occur during the first initial start in the morning.
Cause
This condition may be caused by a lifter not having a sufficient amount of oil during cold start operation (not pumped up).
Correction
To correct this condition, follow the Service Procedure below.
Service Procedure
Allow the engine to sit overnight.
Note: You may need to allow 5-7 minutes to confirm.
  1. Start the vehicle and listen for a tick noise.
  • If a tick noise is present, proceed to the next step.
  • If a tick noise is NOT present after running engine for at least 5 to 7 minutes, release the vehicle back to the customer.
  • Drive the vehicle through the DFM modes.
  • Check for any misfire DTCs and record:
    • If DTCs are found, refer to SI for diagnosis.
    • If no DTCs are found and noise still persists, operate the engine through cylinder Deactivation test to isolate the cylinder with the concern.
  • If the noise has been isolated, inspect for a bent pushrod and/or collapsed lifter.
    • If the pushrods are found to be in working condition, replace the lifters on the affected banks. Refer to Valve Lifter Replacement in SI.
    Parts Information
    Note: Only select the parts that coincide with the repair performed. Replace the part with the P/N outlined in the Electronic Parts Catalog (EPC) in accordance with the vehicle VIN.
    Note: Refer to Service Bulletin 20-NA-038 for additional information on AFM and DFM usage.
    Causal Part
    Description
    Part Number
    Qty
    X
    LIFTER, VLV (Active)
    12680871
    2 per bank (6 CYL DFM)
    4 per bank (8 CYL AFM)
    8 per bank (8 CYL DFM)
    X
    LIFTER, VLV (NON-ACTIVE LIFTERS)
    12648846
    4 per bank (6 CYL)
    4 per bank (8 CYL non DFM)
    N/A
    GASKET, CYL HD (L82, L83, L84)
    12622325
    1
    N/A
    GASKET, CYL HD (L87)
    12688943
    1
    N/A
    GASKET, CYL HD (LC8, L96)
    12610046
    1
    N/A
    GASKET, CYL HD (LT1)
    12659260
    1
    N/A
    GASKET, CYL HD (LV3)
    12632968
    1
    N/A
    GASKET, CYL HD (L86, LT2)
    12688943
    1
    N/A
    BOLT, CYL HD (M12x1.75x102)
    11611976
    Refer to EPC
    N/A
    BOLT, CYL HD (M12x1.75x134)
    11546959
    Refer to EPC
    N/A
    GASKET, VLV RKR ARM CVR
    12619787
    1
    N/A
    GASKET, EXH MANIF
    12657093
    1
    N/A
    PIPE, FUEL FEED INTER
    Refer to EPC
    1
    N/A
    GASKET, INT MANIF
    12626354
    6 (6 CYL)
    8 (8 CYL)
    N/A
    GASKET, W/PMP
    12682391
    1
    N/A
    SEAL, KIT F/INJR (O-ring)
    12672366
    Refer to EPC
    Version
    4
    Modified
    Released February 14, 2020
    May 28, 2020 – Added RPO LT2 to Corvette and Cylinder Head Gasket P/Ns 12632968 (LV3) and 12688943 (L87) to Parts Information.
    December 01, 2020 – Updated the Quantity information for P/N 12626354 and 12672366 in the Parts Information section.
    December 16, 2020 – Added the 2021 Model Year to certain vehicles, added Engine RPOs and updated the Parts Information section.
