2019 Corvette: LT1 LT4 LT5 Engine Oil Part Number Update
Estimated Reading Time: 2 MinutesReference Number: GCUS-9-5752
03-29-2018
Mobil 1 0W40 dexos 2 (19353135) Clarification
To Chevrolet and Cadillac U.S. Dealers:
Mobil 1 0W40 dexos 2 is the recommended engine oil for certain 2019 Corvette, Camaro and Cadillac vehicles.
This product is currently available in 1 liter bottle only (Part number 19353135) for dealer use only. This product should be ordered from the Oil Distributor and asked for by its name "Mobil 1 ESP 0W40".
This product will be available soon in the following pack sizes:
Quart (Part Number 19370233)
55-Gallon Drum (Part Number 19370234)
Until the exact release dates are available (to be announced shortly) Dealers should order 19353135. The pack label is attached for reference.
Key Application Chart
Model | Corvette | Corvette | Camaro | Corvette | Camaro | Corvette | CTS-V | CT6 |
Engine RPO |
LT1 | LT1 | LT1 | LT5 | LT4* | LT4 | LT4 | LTA |
Description | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, HO, AFM, | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, HO, AFM, | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, HO, AFM, | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, SC, AFM, ALUM | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, SC, AFM, ALUM | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, SC, AFM, ALUM | ENGINE GAS, 8CYL, 6.2L, SIDI, VVT, SC, AFM, ALUM | ENGINE GAS, 8CYL, 4.2L, SIDI,VVT,TT,DOHC, AFM,ALUM |
Without Z51 (Wet Sump Oil system) | Z51 (Dry Sump Oil system) | |||||||
Oil Capacity (Quarts/ Liters) |
7.0/6.7 | 9.8 qts / 9.27L track events it is suggested 10.25QTS | 10.0 qts / 9.5 L | 9.8qts/ 9.27L Track events it is suggested 10.25qts | 10.0 qts / 9.5 L | 9.8qts/ 9.27L Track events it is suggested 10.25qts | 10.0 qts / 9.5 L | 10.0 qts / 9.5 L |
*NOT recommended in vehicles with RPO A1Z (1LE package)
DATE | March 26, 2018 |
SUBJECT | 2019 Corvette – Engine Oil Part Number Update |
MODELS | 2019 Chevrolet Corvette |
TO | Service Manager, Parts Manager |
ATTN | Service Manager, Parts Manager |
Please be advised that the new 2019 Corvette LT1, LT4 and LT5 engine utilizes Mobil Dexos2 0W40 The capacity currently available is 1 liter bottles.
The corrected part number is 19353135.
This will be updated in the electronic parts catalogue.
Thank you,
GM CUSTOMER CARE & AFTERSALES
