2020 Corvette: Service Bulletin: #20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set
#20-NA-042: Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set - (Oct 19, 2020)
Subject Fuel Gauge May Intermittently Display Erratic and/or Empty Readings, Malfunction Indicator Lamp (MIL) Illuminated - DTC P0462 Set
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
2020
SOP
L5100151
6.2L (RPO LT2)
Involved Region or Country
North America, Middle East
Condition
Some customers may comment on one or more of the following conditions:
  • Fuel gauge intermittently displays erratic and/or empty readings
  • MIL illuminated
Some technicians may find DTC P0462 (Fuel Level Sensor 1 Circuit Low Voltage) displayed in the Engine Control Module (ECM).
Cause
This condition may be caused by erratic fuel value readings sent from the left fuel tank level sensor.
Correction
If the customer concern has been verified, replace the left side fuel tank level sensor.
Service Procedure
Refer to Fuel Level Sensor Replacement in SI.
Parts Information
Causal Part
Description
Part Number
Qty
X
SENSOR KIT, FUEL LVL
84745186
1
Version
2
Modified
Released March 09, 2020
October 19, 2020 – Added a VIN breakpoint and changed the Warranty Information.
