2020 Corvette: Service Bulletin: #20-NA-157: Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing - (Sep 17, 2020)
Estimated Reading Time: 5 Minutes
Subject Transport Mode On Message Displayed in Driver Information Center (DIC) and/or Battery Light is Flashing
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Buick
Encore
2013
2021
All
All
Encore GX (VIN M)
2020
2021
Envision
2016
2021
Regal Tour X
2019
2020
Cadillac
Escalade Models
2015
2020
CT4
2020
2021
CT5
2020
2021
CT6
2016
2020
XT4
2019
2021
XT5
2017
2021
XT6
2020
2021
Chevrolet
Blazer
2019
2021
Bolt EV
2017
2021
Camaro
2016
2021
Colorado
2015
2021
2020
Equinox
2018
2021
Impala
2014
2020
Malibu (VIN Z)
2016
2021
Silverado
2015
2021
Sonic
2012
2020
Spark
2013
2021
Trax
2013
2021
Suburban
2015
2021
Tahoe
2015
2021
Trailblazer (VIN M)
2021
2021
GMC
Acadia
2017
2021
Canyon
2015
2021
Sierra
2015
2021
Terrain
2018
2021
Yukon
2015
2021
Yukon XL
2015
2021
Involved Region or Country
North America, Europe, China, Japan, GM Korea, Russia, Middle East, Israel, South Africa, Philippines, Thailand, Argentina, Brazil, Chile, Colombia, Ecuador, Peru
Condition
Some customers may comment that the Transport Mode On message is displayed in the DIC and/or the red battery light is flashing. Transport Mode is intended for use for vehicles being shipped over long distances, and includes vehicles shipped into and outside of the United States and Canada.
Some products will be shipped from the assembly plant with Transport Mode On. The Transport Mode feature when enabled reduces the parasitic electrical load on the battery when the vehicle is parked, which extends the battery stand time up to 70 days without the battery going dead.
To alert the operator that Transport Mode On is enabled, the red battery light will be flashing and if equipped with a DIC, it will display a Transport Mode On message. Twenty-four hours after transport mode is turned On, with the vehicle Off, the key must be used to enter the vehicle, as the following functions will be disabled: Passive Entry, Remote Keyless Entry, Content Theft. For 2016 and beyond. Full-Size SUVs (Cadillac Escalade models, Chevrolet Suburban, Tahoe, GMC Yukon Models); the Remote Keyless Entry function will remain enabled during transport mode, allowing entry without a key. Exit lighting timers will function but will be reduced.
Note: For PEPS vehicles in Transport Mode On, the key fob will operate for the Start/Stop button, as long as the fob is inside the vehicle.
When the vehicle is running, the only difference in operation will be the DIC Message and the battery light flashing. The Passive Entry and Remote Keyless Entry functions are restored with the ignition in Run.
The mode should be left On while the vehicle is in dealer inventory. Also a customer may want to use the mode if the vehicle is going to be stored. The method to turn the mode Off is the same to turn the mode On. Refer to the Procedure section.
Tip: The EL-52800 E-XTEQ Diagnostic Charge Battery Station (DCBS) or EL-50313 Midtronics GR8 Battery Tester/Charger must be used for maintaining batteries on new vehicles in dealer inventory.
Procedure
Note: Normal vehicle diagnostics and/or service procedures should not be performed when Transport Mode is On. Turn Transport Mode Off prior to performing system checks or service procedures.
With Transport Mode On, enter the vehicle using the steps below:
  1. 1. Attempt to unlock the vehicle with the FOB.
  2. 2. If the vehicle is not responding to the FOB, press the PEPS door handle switch a few times (if equipped) then attempt to unlock the vehicle with the FOB.
  3. 3. If the vehicle is not responding to the FOB, the key must be used to enter the vehicle.
  4. 4. Turn the Transport Mode On/Off using the vehicle specific procedure.
2019-2021 Chevrolet Silverado and GMC Sierra / 2016-2021 Chevrolet Malibu / 2019-2021 Cadillac XT4
Transport Mode is enabled by activating the hazard flashers, applying the brake pedal, and then turning the ignition key to the start position or pushing the ignition mode switch with the foot on the brake for greater than 15 seconds. The mode is disabled by repeating the previous process. The DIC (if equipped) will display Transport Mode On when enabled and Transport Mode Off when disabled. For vehicles not equipped with a DIC, the battery indicator light will constantly flash on the instrument cluster when Transport Mode is On. This feature can be used as many times as necessary if the vehicle is to be stored for an extended period of time.
2017-2021 Chevrolet Bolt EV
To turn Transport Mode On/Off, start the vehicle (as indicated by the green Ready light), activate the hazard flashers, press and hold the brake pedal, then press and hold the Start/Stop button at least 15 seconds. Transport Mode On/Off message will display on the DIC. Then turn the hazard flashers off. Allow the vehicle to sleep at least 2 minutes prior to restarting.
2016-2021 Buick Envision / 2019-2021 Chevrolet Blazer / 2018-2021 Chevrolet Equinox, GMC Terrain / 2017-2021 Cadillac XT5 / 2017-2021 GMC Acadia / 2020-2021 Cadillac XT6
To turn Transport Mode On/Off, start the vehicle, press the brake pedal, activate the hazard flashers, hold the start button for at least 15 seconds. Transport Mode On/Off message will display on the DIC and the Battery Warning light will flash.
2011-2021 ALL OTHER Vehicles Procedure
To turn Transport Mode On/Off, start the vehicle, activate the hazard flashers, press the brake pedal (automatic transmission) or clutch pedal (manual transmission) then press and hold the Start/Stop button or turn the ignition key to the crank position for 15 seconds. (The engine will turn Off on push button vehicles.) The same steps are used to turn On the feature.
Note: Vehicles that are shipped from the assembly plant with Transport Mode On, turning the feature Off is included in the normal PDI process time. No additional warranty claims should be submitted to disable or enable this feature.
Version
2
Modified
August 12, 2020 – Corporate Service Bulletin Number 11-08-49-001Z has now become Global template format Service Bulletin 20-NA-157 (version 1). This update adds 2020 and 2021 Model Years to certain Models, removes other Models to which the Condition no longer pertains, removes the Attention statement, adds Export regions, updates the Tip regarding battery charging and the Condition and Procedure sections were updated to reflect the proper Model/Model Year changes.
September 17, 2020 – Added the Corvette model.
