2020 Corvette: Service Bulletin: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)
2020 Corvette: #20-NA-217: Improved Electronic Limited Slip Differential (ELSD) Calibration - (Nov 10, 2020)
Subject Improved Electronic Limited Slip Differential (eLSD) Calibration
Brand:
Model:
Model Year:
Breakpoint Date:
Engine:
Transmission:
from
to
from
to
Cadillac
CT5
2020
2020
July 31, 2020
September 10, 2020
Chevrolet
September 30, 2020
Involved Region or Country
North America
Additional Options (RPOs)
Equipped with Electronic Limited Slip Differential (G96)
Condition
Some customers may comment on one or more of the following symptoms while driving the vehicle aggressively:
  • Steering is too responsive on-center or during quick driving maneuvers.
  • Inconsistent wheel slip on corner exit or pulling into traffic.
  • Less stability on corner entry, especially with ESC/TCS turned off.
Cause
The cause of the condition may be an anomaly with the Electronic Limited Slip Differential (eLSD) software in the Brake System Control Module (BSCM).
Correction
Reprogram the BSCM with the latest calibrations.
