2020 Corvette: Service Bulletin: #20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)
Estimated Reading Time: 1 Minutes#20-NA-236: Engine Overheats or Coolant Leak Under Rear of Vehicle - (Feb 10, 2021)
Subject: | Engine Overheats or Coolant Leak Under Rear of Vehicle |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette |
2020 |
2020 |
6.2L (RPO LT2) |
Involved Region or Country |
North America, Middle East |
Condition |
Some customers may comment on one or more of the following conditions:
Cause |
This condition may be caused by the water pump outlet pipe becoming disconnected from the water pump. |
Correction |
Important: Follow the complete coolant bleed process called out in SI. Performing just a vac-n-fill will leave air in the cooling system, potentially causing an overheat condition. Replace the water pump outlet pipe and fully perform the complete bleed procedure after replacing the pipe. |
Service Procedure
Refer to Water Pump Outlet Pipe Replacement - Engine Coolant Manifold to Engine Oil Cooler Adapter in SI.
Parts Information
Causal Part
Description
Part Number
Qty
X
PIPE, W.PMP OTLT
84660333
1
N/A
DEX-COOL®
Refer to EPC
1
Version |
1 |
Modified |
Released February 10, 2021 |
