2020 Corvette: Service Bulletin: #PIP5709G: Dual Clutch Transmission Part Restriction - (Dec 1, 2020)
2020 Corvette: #PIP5709G: Dual Clutch Transmission Part Restriction - (Dec 1, 2020)
Subject Dual Clutch Transmission Part Restriction
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
All
All
All
M1L
Involved Region or Country
North America
Condition
Any internal transmission related complaints.
Cause
Root Cause analysis
The following parts can be obtained for maintenance or servicing per track related events.
The only serviceable components at this time are:
24299326 Filter Kit, Trans Fluid
24299296 Plug, Oil Fill
24299297 Seal, Trans Fill Plug
24299298 Plug, Oil Drn
24299299 Seal, Trans Drn Plug
24299344 Plug, Trans oil fill (Track only, additional fill)
11546938 Retainer, RR Whl Dr Shft UJT
24297480 Hose, Trans Vent
24299294 Cover, Trans Fluid filter
19418016 FLUID, A/TRANS (ACDelco #10-4130) U.S.
19418017 FLUID, A/TRANS Canada
24299321 Seal Asm-Axle (Right)
24299318 Seal Asm-Axle (Left)
24299327 Ring Axle Shft (mLSD)
24299328 Ring Axle Shft (eLSD)
24299304 Seal input shaft
24299330 Gasket, Trans Pan
24299331 Bolt Trans fluid pan qty 13
24299332 Stud Trans fluid pan qty 2
24299351 Seal, C/VB Cover
24299331 Bolt C/VB Cover qty 9
24299332 Stud C/VB Cover
24044927 Seal, Trans Case Cvr (Rear)
24044929 Bolt, trans case cvr(Rear) qty 3
As part of our ongoing continuous improvement we have placed the transmission (P/Ns 24042873 or 24043824 (mLSD) 24042874 or 24043825 (eLSD)) used in the 2020 Corvette on restriction.
This restriction program is in effect to provide quick detection and resolution of any transmission related concerns while allowing limited repairs to the unit itself.
Not all transmission requests may result in transmission replacement. Engineering reviews all requests and it may be determined to allow repairs by the dealer on a case by case basis.
If contacting TAC/PQC about a fluid leak that is suspected to be transmission fluid, refer to Document ID: 5395398 and use the powder method.
Please have pictures of the leak area with the powder applied showing the leak.
Pictures showing the leak area/path will aid in diagnosis and can be attached to the case with the completed template.
Please have the part number available prior to contacting TAC/PQC.
Please contact the Product Quality Center (PQC) by opening a new case via Dealer Case Management (DCM) From the DCM home page, click on "New PQC Case" found on the Technical Assistance tab.
Then in Global Connect click on the Support/Chat tab, TAC-PQC Tab, PQC -Parts Restrictions Templates to Download the PQC PIP5709 2020 Chevrolet Corvette Transmission Restriction Template and save a copy to your computer, You can attach a copy of the template to your PQC Case.
Note: (Do Not clear any DTCs prior to contacting the PQC). To aid in the information gathering process please attach session logs of the VIN to the case. Important things to look at in GDS is the Module Identification screen in the TCM, Vehicle wide DTC scan, Transmission DTC data and any freeze frame or enhanced DTC data lists.
Parts Information
Description
Part Number
Qty
TRANSAXLE, AUTO
1
TRANSAXLE, AUTO W/Z51
1
Warranty Information
For vehicles repaired under the Powertrain coverage, use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation
Description
Labor Time
8464670
Automatic Transmission Replacement
Used Published Labor Time
ADD
Administrative Allowance
0.2 Hr.
Version
8
Modified
02/28/2020 - Created on
05/14/2020 - Updated to add part numbers
08/12/2020 - Updated to add leak diagnostics
08/27/2020 - Updated to change from exchange to restriction.
09/24/2020 - Updated to add part number
10/6/2020 - Updated to add part number
11/02/2020 - Updated to add serviceable part numbers
12/01/2020- Updated to correct labor operation.
