2020 Corvette: Service Bulletin: #PIP5733D: Possible Crank No Start or Extended Crank
#PIP5733D: Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History - (Sep 22, 2020)
Subject Possible Crank No Start or Extended Crank With DTC P12A6 Set As Current or History
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
Escalade
2020-2021
All
All
6.2 L86 L87
All
Chevrolet
All
All
6.2L LT2
All
Chevrolet
Equinox
2020-2021
All
All
1.5 LYX
All
Chevrolet
Malibu
2020-2021
All
All
1.5 LFV
All
Chevrolet
Silverado 1500 (New Model)
2019-2021
All
All
4.3 LV3 5.3 L82/L84 6.2 L87
All
Chevrolet
Silverado 2500/3500
2020-2021
All
All
6.6 L8T
All
Chevrolet
Suburban
2020-2021
All
All
5.3 L83 L84 6.2 L86 L87
All
Chevrolet
Tahoe
2020-2021
All
All
All
GMC
Sierra 1500
2019-2021
All
All
All
GMC
Sierra 2500/3500
2020-2021
All
All
6.6 L8T
All
GMC
Yukon
2020-2021
All
All
All
GMC
Terrain
2020-2021
All
All
1.5 LYX
All
Involved Region or Country
North America
Condition
Possible Crank no start or extended crank with DTC p12A6 set current or history.
Cause
Internal Hardware Issue
Correction
Replace the K20 Engine Control Module (ECM).
Engineering is aware of this concern, this PI will be updated to a bulletin when the permanent fix is released.
Warranty Information
For vehicles repaired under the Emissions (E, E2) coverage, use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Labor Operation
Description
Labor Time
4087548
K20 Engine Control Module Replacement (ECM)
5.3 L83 and 6.2 L86 2020 SUV
Base Time: 0.5 Hr.
Diagnostic Add Time 0.0 - 1.0 Hrs.
5.3 L84 and 6.2 L87 SUV 2021 SUV ST.
1.5 LYX  2020-2021
Base Time: 0.6 Hr.
1.5 LFV 2020-2021
Base Time: 0.6 Hr.
To relearn OAT Sensor: add 0.2 Hrs.
5.3 L82/L84 and 6.2 L87 2019-2021
Base Time: 0.8 Hrs.
6.2L LT2 2020 Corvette: Base time is ST
2.0L LSY Engine CT5 Base time is 1.0 Hrs.
Diagnostic Add time 0.0 – 1 Hrs.
6.6 L8T 2020-2021
Base Time: 1.1 Hrs.
*This is a unique Labor Operation for Bulletin use only.
Version
5
Modified
06/11/2020 - Created on
07/29/2020 - Updated Model Years
08/06/2020 - Updated Model Years and Engine RPO Codes
08/27/2020 - Updated the labor operation
09/21/2020 - Updated to remove Cadillac CT5
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer".  They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle.  Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely.  If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition.  See your GM dealer for information on whether your vehicle may benefit from the information.
