2020 Corvette: Service Bulletin: #PIP5752A: Service Engine Light misfire engine noise With DTC P0300 P0106 P0506 - (Sep 22, 2020)
Subject Service Engine Light misfire engine noise With DTC P0300 P0106 P0506
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Chevrolet
Camaro
2020
All
All
6.2 LT1 LT4
All
Chevrolet
All
All
6.2 LT2
All
Chevrolet
Silverado
2020
All
All
5.3 L82 L84 6.2 L87 6.6 L8T
All
Chevrolet
Suburban
2021
All
All
5.3 L846.2 L87
All
Chevrolet
Tahoe
2021
All
All
5.3 L846.2 L87
All
GMC
Sierra
2020
All
All
All
GMC
Yukon
2021
All
All
5.3 L84 6.2 L87
All
Involved Region or Country
North America
Condition
A Vehicle may have a concern of service engine light, misfire and engine noise with possible of DTC P0300 P0106 P0506.
Cause
Possible broken valve spring.
Correction
During inspection if you determine that the engine has a broken valve spring it will be necessary to perform a cylinder leakage test on the affected cylinder.
If no cylinder leakage is observed it will be necessary to replace all valve springs on both banks if the vehicle is built between June 1, 2020 to September 15, 2020. Note: This only applies to the 6.2L engines RPOs L87, LT1, LT4 and LT2. For all other engine RPOs L82, L84 and L8T just replace the affected valve spring.
If you determine that engine has cylinder leakage it will be necessary to inspect further to determine the extent of the engine damage to determine correct repair required.
Important: All valve springs will be requested back for further analysis and inspection.
Warranty Information
For vehicles repaired under the Powertrain coverage, use published labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
Version
2
Modified
09/08/2020 - Created on.
09/21/2020 - Updated to add 2020 Chevrolet Camaro and edit the correction statement.
