2005 - 2007 Corvette: Service Bulletin: Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE
Service Bulletin #:  99-04-20-002D
Date: June 2006
Subject:  Information on Driveline Clunk Noise When Shifting Between PARK and DRIVE, PARK and REVERSE or DRIVE and REVERSE
Model(s):
2007 and Prior GM Passenger Cars and Light Duty Trucks
2007 and PriorHUMMER H2, H3
2005-2007 Saab 9-7X
  • Attached Files
  • 99-04-20-002d.pdf (60.79 KB) 933
