2006 Corvette: Service Bulletin: Diagnosis of Cracked or Broken Transmission Case
Service Bulletin #:  02-07-30-024B
Date: August 2005
Subject:  Diagnosis of Cracked or Broken Transmission Case
Model(s):
2006 and Prior Cars and Light Duty Trucks
2006 and Prior Hummer H2
2006 Hummer H3
2005-2006 Saab 9-7X
with 4L60/4L60-E/4L65-E or 4L80-E/4L85-E or Allison Series 1000 Automatic Transmission
  • Attached Files
  • 02-07-30-042b.pdf (59.34 KB) 728
