2007 Corvette: Service Bulletin: Diagnostic Tips for Automatic Transmission DTC P0756, Second, Third, Fourth Gear Start
Service Bulletin #:  01-07-30-036F
Date: February 2006
Subject:  Diagnostic Tips for Automatic Transmission DTC P0756, Second, Third, Fourth Gear Start
Model(s):
2007 and Prior Passenger Cars and Light Duty Trucks
2003-2007 Hummer H2
2006-2007 Hummer H3
2005-2007 Saab 9-7X
with 4L60-E, 4L65-E or 4L70-E Automatic Transmission (RPOs M30, M32 or M70)
  • Attached Files
  • 01-07-30-036f.pdf (53.58 KB) 607
