2007 Corvette: Service Bulletin: Instrument Panel (I/P), Body and General Wiring Harness Repair
Service Bulletin #:  06-06-45-004
Date: May 2006
Subject:  Instrument Panel (I/P), Body and General Wiring Harness Repair
Model(s):
2007 and Prior GM Cars and Trucks
2003-2007 HUMMER H2
2006 - 2007 HUMMER H3
Attached below is the PDF for this service bulletin.
  • Attached Files
  • 06-06-45-004.pdf (52 KB) 1205
