2004 - 2007 Corvette: Service Bulletin: Engine and Automatic Transmission/Transaxle Identification
Service Bulletin #:  06-00-89-031
Date: June 2006
Subject:  Engine and Automatic Transmission/Transaxle Identification
Model(s):
2004 - 2007 GM Passenger Cars and Trucks (Including Saturn)
2004-2007 Hummer H2
2006-2007 Hummer H3
2005-2007 Saab 9-7X
  • Attached Files
  • 06-00-89-031.pdf (62.33 KB) 784
