2005 Corvette: GM TechLink: Gasoline Engine Oil Requirements
2005 GM gasoline engines require the use of an engine oil that has the American Petroleum Institute (API) Starburst and states that it meets GM Standard GM6094M (non-synthetic) or GM4718M (synthetic). Failure to use the recommended engine oil can result in engine damage not covered by warranty.
In the March 2005 issue, TechLink published a list of engine oil brands that meet GM Standard GM6094M and GM4718M. This list has be updated through April 12, 2005.
TIP: This list will be updated in the future as required.  Download the latest PDF document on the left.
