2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870
Service Bulletin #:  02-07-30-001D
Date: December 2005
Subject:  Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870
Model(s):
2000-2006 GM Passenger Cars and Light Duty Trucks
2003-2006 Hummer H2
2006 Hummer H3
2005-2006 Saab 9-7X
with 4L60E or 4L65-E Automatic Transmission
Attached below is the PDF for this service bulletin.
  • Attached Files
  • 02-07-30-001d_copy1.pdf (56.59 KB) 664
