1997 - 1998 Corvette: Service Bulletin: Loose Lower Front Fascia Valence Panels
Estimated Reading Time: 2 Minutes Source: Chevrolet Dealer Service Bulletin
Number: 73-15-12A
REVISION: 07/14/98 DIVS INVL 1 7
THIS BULLETIN IS BEING REVISED TO ADD 1998 VIN BREAKPOINT INFORMATION. PLEASE DISCARD CORPORATE BULLETIN NUMBER 73-15-12 (SECTION 10 - BODY)
SUBJECT: LOOSE LOWER FRONT FASCIA VALANCE PANELS (INSTALL ADDITIONAL ADDITIONAL WASHERS)
MODELS: 1997-98 CHEVROLET CORVETTE - BUILT PRIOR TO VIN BREAKPOINT W5127967
CONDITION:
SOME OWNERS MAY COMMENT THAT THE LOWER FRONT FASCIA VALANCE PANELS APPEAR LOOSE.
CAUSE:
THE ORIGINAL WASHERS ON THE BOLTS/SCREWS THAT ATTACH THE LOWER VALANCE PANELS TO THE FRONT FASCIA MAY HAVE WORKED THEIR WAY THROUGH THE HOLES IN THE VALANCE PANELS.
CORRECTION:
ADD ONE ADDITIONAL LARGER FLAT WASHER, P/N 11500365, 25 MM O.D. BY 6.3 MM I.D. BY 2.5 MM THICK (1 IN. O.D. BY 1/4 IN. I.D. BY 3/32 IN. THICK) TO EACH OF THE EIGHT BOLTS/SCREWS (FOUR PER VALANCE PANEL) THAT ATTACH BOTH LOWER VALANCE PANELS TO THE FRONT FASCIA (SEE FIGURE 1). TIGHTEN BOLTS TO 7 N.M (62 LB IN).
IMPORTANT:
VEHICLES BUILT AFTER THE ABOVE LISTED VIN BREAKPOINTS HAVE VALANCE PANELS WITH A SMALLER HOLE DIAMETER AND NEW FASTENERS. AS A RESULT, IT IS NOT NECESSARY TO INSTALL ADDITIONAL WASHERS ON THESE VEHICLES.
PARTS INFORMATION:
PARTS QUANTITY REFLECTS THE NUMBER REQUIRED TO DO BOTH LEFT AND RIGHT LOWER VALANCES ON ONE VEHICLE.
P/N DESCRIPTION QUANTITY PACKAGED QUANTITY
11500365 WASHER 8 1
PARTS ARE CURRENTLY AVAILABLE FROM GMSPO.
WARRANTY INFORMATION:
FOR VEHICLES REPAIRED UNDER WARRANTY, USE:
LABOR OPERATION LABOR OPERATION NUMBER DESCRIPTION TIME
B0392 AIR VALANCE, RIGHT 0.3 HR AND LEFT SIDE - REPLACE
![](/tech/knowledgebase/images/tech/73-15-12A.gif)
