1997 Corvette: Service Bulletin: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened
Estimated Reading Time: 1 Minutes Subject: Water Drips into Rear Compartment After Hatch/Glass Has Been Opened (Modify Weatherstrip)
Number: 73-10-55
Models: 1997 Chevrolet Corvette
Condition: Some owners may comment that water drips into the rear compartment after the hatch glass has been opened.
Correction: Modify weatherstrip following instructions below.
PROCEDURE:
- Pull down weatherstrip to gain access to the end of the black close out weatherstrip (see Figure 1, top view). With a utility knife, cut the close out weatherstrip so there is a 2 MM (3/16 in.) overhang of the weatherstrip to its mounting surface (See Figure 1, top view)
- With weatherstrip pulled down, measure 18 MM (3/4 in.) from end of weatherstrip and remove shaded area from weatherstrip (see Figure 1, bottom view). Reinstall weatherstrip on hatch.
![](/tech/knowledgebase/images/tech/73-10-55.gif)
WARRANTY INFORMATION:
For vehicles repaired warranty, use:
Labor Operation Number: C1280 Labor Operation Time: 0.3 HR
