1966 Corvette: Technical Article: Rear Bulb Re-incarnation
By John Hinckley, Corvette Enthusiast Magazine
Used here with permission.
Copyright John Hinckley, Corvette Enthusiast Magazine
Reader’s Question:
I recently bought a nice “driver” ’66 four-speed coupe, and my backup lights don’t work. Replacing the bulbs didn’t help, and the bulb sockets don’t show any  power when it’s in reverse with the ignition on. Where is the switch and wiring? I see an unused, open two-wire connector hanging from the harness that runs across the firewall – does that have anything to do with the backup lights?
The 1-page PDF document is linked below:
  • Attached Files
  • c2_backup_light.pdf (1.81 MB) 535
