Chevrolet Service Bulletin: Information on Proper Tire Pressure
Service Bulletin #:  00-00-90-002C
Date: August 2005
Subject:  Information on Proper Tire Pressure
Model(s):
2006 and Prior Passenger Cars and Trucks (Including Saturn)
2006 and Prior HUMMER H2
2006 HUMMER H3
2005 - 2006 Saab 9-7X
This bulletin is being revised to add additional information regarding temperature and tire pressure.  Please discard Corporate Bulletin Number 00-00-90-002B (Section 00 -- General Information)
  • Attached Files
  • 00-00-90-002c.pdf (47.89 KB) 633
