Chevrolet Service Bulletin: Information on Tire Radial Force Variation (RFV)
Service Bulletin #:  00-03-10-006A
Date: June 2005
Subject:  Information on Tire Radial Force Variation (RFV)
Model(s):
2006 and Prior Passenger Cars and Light Duty Trucks
2006 and Prior HUMMER H2
2006 HUMMER H3
2000 - 2005 Saturn L Series
2003 - 2006 Saturn ION
This bulletin is being revised to add additional models, model years and additional information.  Please discard Corporate Bulletin Number 00-03-10-006 (Section 03 -- Suspension)
  • Attached Files
  • 00-03-10-006a.pdf (96.02 KB) 557
