Technical Article: How to Install a BG Speed Demon (Basic)
How to Install a BG Speed Demon (basic)
by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. D 4-2-10
Getting a BG Speed Demon carb set up and running right on your engine is all in the prep work:  A few bench settings are required, and it’s important to use the right combination of modified parts and accessories to make the installation look good and perform properly.  Here are the basic steps (these steps are also detailed in my Tech Paper, "How to Set up a BG Speed Demon."  Drop me an e-mail request for a copy of this paper:  V8FastCars@msn.com):
See attachment below:
  • Attached Files
  • bg_carb_installation.pdf (537.03 KB) 1851
