Technical Article: How to Set Up a BG Speed Demon (basic)
by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. C 1-2-10
This tech paper will discuss basic set-up of the Barry Grant Speed Demon carbs to establish an initial starting point for a good-running carb.
See attachment below:
  • Attached Files
  • bg_carb_setup_paper.pdf (145.71 KB) 1120
