Technical Article: Problems I have Seen with Commercially Rebuilt Q-Jets
by Lars Grimsrud
©2010 Lars Grimsrud.
This article may not be published or distributed without the written permission of the author
Rev. D 10-2-10
As the Q-Jet carbs keep getting older, fewer and fewer are original carbs that have not been tampered with or altered.  Rebuilding a Q-Jet is becoming a significant problem for the novice, because the carbs cannot be simply bolted together the way they came apart:  The carbs have been altered, and these alterations must be identified and corrected before the carb will run as it was designed to do.
See attachment below:
  • Attached Files
  • commercially_rebuit_q-jet_problems.pdf (236.91 KB) 1336
