Buying: Buying a Corvette and What to Look For
Description:
Buying a used Corvette can be quite intimidating if your new to Vettes and not sure what all the jargon is or what to look for. Use our handy check list (printable) to help you purchase your next Corvette.
Excerpt:
"Buying your first Corvette can be a difficult task if you’re not sure what to look for. You’ve heard all the terms, "matching numbers", "body-off restoration", "frame-off restoration" etc. but you’re not sure what they mean. Our goal here is to provide you with a little bit of knowledge before you go into the Corvette buying world and to supply you with a handy check list of items that you may want to check out the Corvette that you’re interested in purchasing. Depending on options, some of the items on the list, may or may not apply to the particular Vette that you’re looking at. Hopefully, we’ve compiled a fairly broad enough array of items to look at that will cover just about all Corvette model years."
Link:
Buying a Corvette
