Subject: Disc Brake Shoe Organic Lining Wear
Model and Year: 1967 Passenger with RPO J52 Disc Brakes and Corvette with Base Disc Brakes (#752) (T.N.)
Bulletin No: NA
Section: UPC V - Brakes
Date: February 1968
Tapered brake shoe lining wear on the 1967 organic disc brakes is inherent in the design and reduces overall brake lining life. If during brake inspection tapered shoe wear is noted, rotate the shoe assemblies from inner to outer disc locations. This will even out the wear pattern and allow for maximum brake lining durability. The brakes should be burnished before returning the vehicle to the customer.
Article ID: 1005
Created: November 20, 2014
Last Updated: November 20, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-disc-brake-shoe-organic-lining-wear-1005.html
