Subject: Inadequate Cooling
Model and Year: 1968 Corvette with 327 Cubic Inch Engine
Source: Chevrolet Service Technical Bulletin
Bulletin No: 68-T-13
Section: VI
Date: May 22, 1968
TO: ALL CHEVROLET DEALER
This bulletin is a supplement to Chevrolet Dealer Service Technical Bulletin 68-T-9.
Early 1968 Corvettes equipped with the 327 cu. in. engine may be subject to an engine overheating complaint.
The following changes have been made in production to provide improved cooling, effective with the serial numbers, as listed:
If engine overheating is experienced on earlier units with the 327 cu. in. engine, the above corrections should be made as outlined on the following pages. Obviously, other conditions can be involved in overheating and should be considered along with the changes recommended in this bulletin.
Chevrolet Motor Division
General Motors Corporation
INADEQUATE COOLING - 1968 CORVETTE WITH 327 CUBIC INCH ENGINE
If engine overheating complaints are experienced, the following corrections should be made only on earlier units than those serial numbers indicated on page 1.
On cars with L-79 and air conditioning (no power steering) it will be necessary to remove the water pump and water pump rear cover; and using an arbor press, push the water pump hub 1/8" further back on the water pump shaft. Be certain that the shaft is firmly supported on the press anvil to prevent damage to the bearing.
Article ID: 1025
Created: December 1, 2014
Last Updated: December 1, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-inadequate-cooling-1025.html
