Subject: Noise in Direct Drive 4-Speed Manual Transmission
Model and Year: 1984 - 1985 Corvette
Bulletin No: 85-111
Section: 7B
Date: Aug., 1985
Some 1984 - 1985 Corvettes equipped with the 4-speed manual transmission with automatic overdrive may experience a noise in all gears (1st, 2nd, 3rd, and 4th) during direct drive operations (overdrive disengaged).
This condition may be caused by a worn annular bearing on the planetary gear carrier (see illustration). Continued operation of a noisy transmission in the direct drive model will cause damage to the planetary carrier, adapter plate, input sun gear, and input sun gear oil seal. if the input sun gear oil seal is damaged, it is possible for overdrive unit oil (Dexron II) to leak into the manual portion of the transmission.
On transmissions beginning with serial number D5C 14413 CF, a new planetary gear carrier has been released. This carrier (P/N 14094571) incorporates an annual bearing with increased thrust capacity.
Complaint vehicles will have transmissions built prior to serial number D5C 14413 CF. These transmissions are to be repaired by disassembling the overdrive unit according to the appropriate section in the Vehicle Services Manual to enable the following to the be carried out:
NOTICE: When an overdrive unit from a transmission built prior to serial number D5C 14413 CF is disassembled for any reason, it is recommended that a new, P/N 14094571, planetary gear carrier be installed to prevent potential future annular bearing failures.
The overdrive unit’s serial number is on a metal tag attached to the oil pan by one of the pan retaining bolts on the front pan rail.
In addition, if the overdrive unit is from a transmission built prior to serial number D4L 10837CD, it is recommended that a new direct clutch thrust washer be installed to prevent potential future washer hang-up occurring. Replacement procedure for the direct clutch thrust washer is detailed in Chevrolet Service Bulletin #85-68.
Article ID: 1031
Created: December 9, 2014
Last Updated: December 9, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-noise-in-direct-drive-4-speed-manual-transmission-1031.html
