1975 Corvette: Service News: Radiator and Fan Shroud Removal
Subject: Radiator and Fan Shroud Removal
Model and Year: 1975 Corvette
Page Number: NA
Date: February 1975 - Volume 47 - #2
Published information on 1975 Corvette models (refer to 1975 Service and Overhaul Manual Supplement, Page 13-5, Fig. 5) does not include a procedure for removal of the radiator and fan shroud.
Removal and replacement should be performed as follows:
- Disconnect the battery ground cable.
- Remove radiator cap when engine is cool by:
- Slowly rotating cap counterclockwise to detent (do not press down while rotating).
- Wait until any residual pressure (indicated by a hissing sound) is relieved.
- After all hissing ceases, press down on cap while continuing to rotate counterclockwise.
CAUTION: To avoid the danger of being burned, do not remove radiator cap while engine and radiator are sill hot because scalding fluid and steam will be blown out under pressure.
- Place vehicle on a hoise.
- Open the drain cock and drain the radiator.
- Disconnect transmission oil cooler lines if so equipped.
- With help from an assistant, remove the hood.
- Remove the fan shroud to radiator support brackets.
- Remove the two (2) hood hinge forward bolts.
- Remove six (6) radiator side support bolts. Access to these bolts is at wheel housing.
- Remove two (2) radiator support bottom bolts and center brace.
- Pull radiator support forward and clamp with a C-clamp to the right hood hinge.
- Disconnect upper radiator hose and overflow rube hose at radiator.
- Disconnect lower radiator hose at radiator.
- With help from an assistant, remove the radiator from the vehicle.
- Remove the outer fan extension shroud.
- Remove radiator shroud (inner) lower bolts and remove radiator shroud.
- To install, reverse Steps 1-16 above.
- Add sufficient ethylene glycol coolant, meeting GM Specification 1899-M, to provide the required freezing and corrosion protection--at least a 50 percent solution (-20°F). Fill radiator to the base of radiator fill neck and add sufficient coolant to recover tank to raise level to the "FULL-COLD" mark. Reinstall recovery tank cap.
- Run engine, with radiator cap removed, until normal operating temperature is reached. (Radiator upper hose becomes hot.)
- With engine idling, add coolant until level reaches bottom of filler neck and install radiator cap making arrows on cap line up with overflow tube.
Article ID: 1046
Created: December 20, 2014
Last Updated: December 20, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html
