Subject: Engine Harness Cut by Casting Flash on Transmission Housing
Model and Year: 1987 Corvette
Bulletin No: 87-207
Section: 8A
Date: Sept., 1987
Some 1987 Corvettes may experience a variety of engine type electrical problems relating to the main engine wiring harness. These problems may be caused by sharp casting flash on the top, center line of the transmission case cutting into the wiring harness. This area is located directly behind the engine distributor.
A vehicle with this condition may be hard to diagnose since a variety of systems could be affected. Some vehicles have had erratic speedometers, TCC shudder at low speeds, or blown gauge fuses. other systems that may be involved include injectors, ignition, A/C, etc.
Partial access to the area where the harness is being cut can be obtained by removing the distributor. If sharp metal flash exists on the transmission, it should be filed down and covered with protective tape. If the wiring harness has been cut, it should be repaired using the appropriate wire repair procedures from Section 8A of the 1987 Corvette Shop manual.
Use appropriate labor times.
Chevrolet Motor Division
General Motors Corporation
Article ID: 1062
Created: December 28, 2014
Last Updated: December 28, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1987-corvette-service-bulletin-engine-harness-cut-by-casting-flash-on-transmission-housing-1062.html
