Subject: Spark Plug Electrode Interference With Piston
Model and Year: 1961 Corvette Models Equipped with Fuel Injection
Source: Chevrolet Service and Mechanical Department - Technical Information - 1961 Product Data Book
Bulletin Number: Page 3-4 - Section VI - Group 2
Date: 7/8/61
An interference condition between the spark plug ground electrode and piston dome may occur on 1961 Corvette Models equipped with fuel injection. This interference results in a bent electrode which causes insufficient spark plug gap, engine miss and subsequent poor performance.
PRODUCTION
The condition was corrected in Production effective 5-15-61 (engine date stamp F-0515) by removing 1/16" of the piston dome at the contact area as shown in the following sketch. The size of the area to be removed is approximately 1/16" thick, 1/8" wide and 1-1/2" long machined at a 50° angle. Only the top half of the dome chamfer should be removed with the lower portion remaining at the existing 30° angle.
SERVICE
To correct this condition on vehicles built before the Production change, proceed as follows:
REBUILD INFORMATION
In the event an 11:0-1 compression ratio engine equipped with fuel injection is being overhauled or if the cylinder heads are removed, each piston dome should be filed or ground off approximately 1/16" to prevent spark plug electrode interference. if only the heads are removed, the pistons should be at TDC and grease applied to the top of the pistons to insure complete remove of filings.
Article ID: 1066
Created: December 29, 2014
Last Updated: December 29, 2014
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-chevrolet-product-engineering-technical-information-spark-plug-electrode-interference-with-piston-1066.html
