Subject: Anti-Theft Alarm Switch - Protective Grease
Model and Year: 1977 Corvette
Bulletin No: 77-T-57
Section: XII
Date: Oct., 1977
Some 1977 Corvettes may experience inadvertent operation of the theft alarm because of electrolytic corrosion between the anti-theft switch (brass contactor ring) and left hand door lock assemblies. This corrosion can, in some cases, provide an electrical path to ground which sets off the anti-theft alarm.
Vehicles potentially affected by this problem are those produced between VIN’s 1Z37L7S427373 (the point at which the anti-theft switch was moved from the L.F. fender to the L.H. door lock) and 1Z37L7S441024 (application of grease to contactor ring in production).
Vehicles in the field affected by this condition can be corrected by application of a protective grease to the surface of the brass contactor ring portion of the switch as follows:
A satisfactory substitute for Packard Electric PM-771 grease is GM P/N 1050109 or 1050110.
Article ID: 1104
Created: January 13, 2015
Last Updated: January 13, 2015
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html
