1967 Corvette: Engineering Service Letter Note: Steering Shaft Upper Retaining Ring Removal on Telescoping Columns
Subject:    Steering Shaft Upper Retaining Ring Removal on Telescoping Columns (#608) (T.N.)
Model and Year:  1967 Corvair, 1967 Corvette
Source:  Chevrolet Engineering Service Letter Note
Page Number:   NA
Date:  February - March 1967
The subject retaining ring is a two winding spiral type instead of the snap type as shown in the Chassis Service Manual, Section 9, Item 16, Fig. 54; and the Corvette Manual, Section 9, Item 26, Fig. 9.
The retaining ring can be removed using a small screwdriver.  Place the blade of the screwdriver under the end of the ring and pry out and up while rotating the shaft.  Install a new ring when reassembling.
Article ID: 1106
Created: January 15, 2015
Last Updated: January 15, 2015
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-engineering-service-letter-note-steering-shaft-upper-retaining-ring-removal-on-telescoping-columns-1106.html
