1955 Corvette: Service Bulletin: Upshift at Part Throttle
Subject:   Upshift at Part Throttle
Model and Year:   1955 6-Cylinder Powerglide
Bulletin No:   DR - 192
Section:   VII
Date:    January 31, 1955
TO:  ALL CHEVROLET DEALERS
In cases where the 1955 6-Cylinder Powerglide Units upshift in the 25 - 28 MPH range on part throttle, and it is desirable to have the upshift at 12 - 18 MPH for best fuel economy, particularly in Metropolitan areas, a new Throttle Valve Control Outer Lever and Control Rod should be installed and linkage readjusted.
The new Control Rod and Outer Lever went into production at assembly plants during week of 1-10-55.
PARTS
Description New Part No. Old Part No.
Throttle Valve Control Outer Lever 3720325 (Change in angle) 3710634
Control Rod 3715711 (Shortened) 3710632
THROTTLE VALVE LINKAGE ADJUSTMENT
Article ID: 1110
Created: January 17, 2015
Last Updated: January 17, 2015
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html
