Subject: Directional Signal Switch Removal and Installation
Model and Year: 1969 Tilt-Telescoping Column
Page Number: 8
Date: March 1969 - Volume 41 - Number 3
Procedures for removal and installation of the directional signal switch on the 1969 Corvette Tilt-Telescoping steering column specify the use of Tool J-22191 to remove and install the "C" ring which retains the horn contact assembly in position on the steering shaft. Although this procedure will work satisfactorily, extreme care must be used to prevent the tool from slipping off the contact assembly and braking the plastic carrier projections.
The following procedure is recommended in place of that stated in Step 2 of the ’Removal’ and Step 4 of the ’Installation’ procedures appearing on Page 9-10 of the 1969 Passenger Car Chassis Service Manual:
Reverse these procedures for installation of the switch.
Article ID: 1136
Created: January 26, 2015
Last Updated: January 26, 2015
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-directional-signal-switch-removal-and-installation-1136.html
