Subject : | Brake Pulsation and/or Vibration During Brake Apply |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Chevrolet |
Corvette |
2014 |
2016 |
Involved Region or Country |
North America and NA Export vehicles. |
Additional Options (RPO) |
BRAKE SYSTEM-HEAVY DUTY (RPO J55) |
Condition |
Some customers may comment on a pulsation and/or vibration when they apply the brakes. Customer may also comment they hear a rattle noise from the wheel area. The noise may go away when the brakes are lightly applied. |
Cause |
This condition may be due to excessive lateral runout (LRO) or interation between the inner top hat section to the rotor ring. |
Check the lateral runout:
Important: The rotors MUST be replaced as a pair due to a design change.
Note: DO NOT replace all brake rotors unless you find the lateral runout out of spec for both the front and rear corners.
Refer to Brake Rotor Assembled Lateral Runout Correction and Front and Rear Brake Rotor Replacement-Both Sides in SI.
Description |
Part Number |
Qty |
ROTOR ASM-FRT BRK |
23242229 |
2 |
ROTOR-RR BRK |
23322785 |
2 |
Article ID: 1270
Created: May 28, 2016
Last Updated: July 21, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-170-brake-pulsation-and-or-vibration-during-brake-apply-1270.html
