Subject: | Track Use Power Steering Gear Cooling Duct | |
Models: | 2014 - 2016 Chevrolet Corvette | |
Attention: | This PI also applies to any of the above models that may be Export from North America vehicles. |
This PI has been revised to update the applicable information below including adding Warranty Information. Please discard PI1535.
Some customers may comment a DIC message that reads “Service Power Steering Gear" and/or feeling a reduction in steering assist while driving their vehicle on the track during hot days. Technicians may find DTC C0174 stored.
This condition may be caused when there is an increase in temperature with the steering gear.
Install a new power steering gear cooling duct following the procedure below.
Note: This might require multiple cuts to the duct (3) and test fittings.
*Contact Kent Automotive at 1-888-YES-KENT or online at www.kent-automotive.com.
Part Number |
Description |
Qty |
15842373 |
DUCT-RR BRK CLPR CLG |
1 |
23135212 |
DEFLECTOR-F/CMPT AIR |
1 |
P26118* |
Plastic Rivet - 17/64" Hole Diameter; 3/32" - 3/16" Grip Range; 11/16" Flange Diameter; Black Nylon |
2 |
Article ID: 1271
Created: May 28, 2016
Last Updated: May 28, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pi1535a-track-use-power-steering-gear-cooling-duct-may-24-2016-1271.html
