Subject: | Delayed Engagement After Sitting With Engine Off | |
Attention: | This Bulletin also applies to any of the models that may be Export vehicles. |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
Escalade |
2015 |
2016 |
8L45 or 8L90 |
Cadillac |
Escalade ESV |
2015 |
2016 |
8L45 or 8L90 |
Cadillac |
ATS |
2016 |
2016 |
8L45 or 8L90 |
Cadillac |
CTS |
2016 |
2016 |
8L45 or 8L90 |
Chevrolet |
Corvette |
2015 |
2016 |
8L45 or 8L90 |
Chevrolet |
Silverado |
2015 |
2016 |
8L45 or 8L90 |
GMC |
Sierra |
2015 |
2016 |
8L45 or 8L90 |
GMC |
Yukon |
2015 |
2016 |
8L45 or 8L90 |
GMC |
Yukon XL |
2015 |
2016 |
8L45 or 8L90 |
Condition |
Some customers may comment on a condition of delayed engagement when the transmission is shifted from Park to Reverse or Park to Drive after the vehicle has been sitting with the engine off. This condition may typically occur after several hours or more commonly overnight. Customers may describe this condition as the vehicle not wanting to move or feeling like the transmission is slipping when first trying to move the vehicle. Operation will be normal and the condition will not occur until the vehicle sits again with the engine off for several hours or overnight. |
Install a new stator shaft support assembly that includes an additional check ball. Follow the instructions below to replace the stator shaft support assembly.
Note: The fluid pan gasket is reusable. Inspect the gasket to determine if it may be reused. If the gasket is stuck to the case or pan, it should be replaced.
Note: The driven sprocket locking tab is located on the back of the sprocket. Rotate the sprocket as shown and simultaneously pull back and up on the tab to release the retainer.
Note: There are 2 different front cover configurations. Early design front covers have 3 threaded holes for service, late design front covers have 2 threaded holes.
(A) | Old stator support asm 24274636/24275106/24272656 |
(B) | New stator support asm 24277234 |
Note: The new stator shaft support assembly has a second check ball (1) added (see illustrations).
Caution: Size the converter fluid seal ring for at least 5 minutes after installation to obtain proper seal ring size. Failure to do so may cause internal transmission leaks and transmission damage.
Note: Use the large taper side of DT-50912-1 Seal Sizer for initial seal sizing, then flip the tool over for final sizing. The DT-50912-1 seal sizer works for both the 8L90 and 8L45.
Note: Align the bolt hole indicated by the arrow with the arrow that is cast into the case and push down to seat.
(A) | Old cover 24272660 |
(B) | New cover 24277964 |
Note: The casting void has been eliminated from the underside of the cover (see illustration).
Note: Ensure the drive link assembly is not pinched by the front cover and moves freely on the drive sprocket.
Note: Ensure the driven sprocket locking tab is in the unlocked position before installing the sprocket. The driven sprocket locking tab is located on the back of the sprocket and faces the pump.
Description |
Part Number |
Qty |
Trans Model |
Component Number in Disassembled Views |
GASKET-A/TRNS FLUID PAN |
24260071 |
1 (if required) |
8L45/8L90 |
48 |
BOLT/SCREW-A/TRNS FLUID BFL |
11548404 |
2 |
8L45/8L90 |
12 |
BOLT/SCREW-A/TRNS CASE FRT CVR |
11548201 |
11 |
8L45/8L90 |
3 |
SEAL-A/TRNS CASE FRT CVR |
24266366 |
1 (if required) |
8L90 |
5 |
24251906 |
1 (if required) |
8L45 |
5 |
GASKET-A/TRNS FRT SUPT CVR |
24272658 |
1 |
8L90 |
19 |
24264863 |
1 |
8L45 |
19 |
WASHER-DRV SPKT THR (FRONT) |
24259119 |
1 (if required) |
8L45/8L90 |
6 |
WASHER-DRV SPKT THR (REAR) |
24259427 |
1 (if required) |
8L45/8L90 |
8 |
SEAL-TURB SHF (O RING) |
24261849 (Part of 24271697 kit) |
1 |
8L90 |
500 |
24261848 (Part of 24277071 kit) |
1 |
8L45 |
500 |
SUPPORT ASM-STATOR SHF |
24277234 |
1 |
8L90 |
14 |
24277230 |
1 |
8L45 |
14 |
COVER-A/TRNS CASE FRT |
24277964 |
1 (if required) |
8L90 |
4 |
SEAL-T/CV FLUID |
24259216 |
1 |
8L45/8L90 |
18 |
RING-1-3-5-6-7 CLU FLUID SEAL |
24266593 |
2 |
8L90 |
15 |
24266594 |
2 |
8L45 |
15 |
SEAL ASM-T/CV FLUID |
24266709 |
1 |
8L45/8L90 |
2 |
FLUID, A/TRANS (DEXRON HP ATF) (1 QUART) |
19300536-US 19300537-CA |
As Required |
8L45/8L90 |
Article ID: 1275
Created: June 10, 2016
Last Updated: June 10, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-delayed-engagement-after-sitting-with-engine-off-1275.html
