Subject: | Diagnostic Tip for Malfunction Indicator Light (MIL) Illuminated, DTC P0420 and P0430 Set | |
Attention: | This Bulletin also applies to any of the models that may be Export from North America vehicles. |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
Cadillac |
CTS |
2016 |
2016 |
LT1, LT4 |
Escalade |
2015 |
2016 |
L83, L86 |
Escalade ESV |
2015 |
2016 |
Chevrolet |
Camaro |
2016 |
2016 |
LT1, LT4 |
Corvette |
2014 |
2016 |
Silverado |
2014 |
2016 |
L83, L86, LV1, LV3 |
GMC |
Sierra |
2014 |
2016 |
Yukon |
2015 |
2016 |
L83, L86 |
Yukon Denali |
2015 |
2016 |
Yukon XL |
2015 |
2016 |
Yukon XL Denali |
2015 |
2016 |
Condition |
Some customers may comment that the Malfunction Indicator Light (MIL) is illuminated. Technician may find DTC PO420 and P0430 set. |
Cause |
![]() ![]() This may be caused by excessive sand and/or debris entering the air filter box and bypassing the seal of the air filter, due to not properly sealing, causing damage to the HO2 sensor element (3) and the catalytic converter to become blocked with sand and debris particles (1, 2). |
Do not replace any of the parts until the air filter housing has been validated to be completely sealed.
If the condition is evident, inspection of the air box and air filter seal must be done.
Follow the Service Procedure steps in order to verify the sealing of the air filter to housing surface.
After validating the air box has been sealed, repair the P0420 and the P0430 codes as needed.
Labor Operation |
Description |
Labor Time |
4020470 |
Air Cleaner Element Replacement |
Use Published Labor Operation Time |
4020390 |
Air Cleaner Assembly Replacement |
Version |
2 |
Modified |
May 31, 2016 – Added repair as needed for codes P0420, P0430 in Correction. |
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of |
Article ID: 1277
Created: June 15, 2016
Last Updated: June 15, 2016
Online URL: https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html
